Welding cable vs. OFC
Hey, quick question. Is there a big difference between welding cable and OFC cable? I know, CCA is inferior, but I have seen people use wading cable in their instals. Reason I ask is because I have come across some on E-bay at reasonable price and might use it as my power from front to back. Here is the link.http://www.ebay.com/itm/25-1-0-WELDING-CABLE-EXCELENE-RED-MADE-USA-/190826363373?pt=LH_DefaultDomain_0&hash=item2c6e2339ed
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
They are both pure copper, just welding cable isn't as flexible and you need 2/0 to have it compare to good CA wire, but it's cheaper.
The jacket isn't made for underhood applications, so if you use it for that, use wire sleeve to protect the wire.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Ok, well I am thinking about running it under my car, along the frame, so flexibility should't be an issue. I am thinking the 1/0 should be good for me, as I am only running about 2000 total watts. My plan is to run a smaller battery in the back, and this would be my battery to battery cable.
Hey, I am in Orlando, about 20 minutes down the highway for ya
Keep in mind, I'm currently running the JL Audio 2 AWG OFC at 20% off while I have it. This includes our 2 AWG Add-A-Battery Kits that is a perfect complement to your Big 3 Upgrade kit - includes all components necessary to safely run under your vehicle.
http://www.ceautoelectricsupply.com/addabatterykit.html
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
welding wire has less stands but their thicker and the resiston is higher causing the wire to get warm just to be safe get the 2/0 it'll be the same as having 1/0 audio wire.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
here the link someone did here about size difference scroll down about half way theirs a pic someone comparing knu 1/0 to 2/0 welding
http://www.stevemeadedesigns.com/board/topic/150690-welding-cable/
2 sundown sd-2 d4
flex tech
box design by Joe X
U could always hit up a junkyard and try to pull a good power wire out of a bmw..they been having the battery installed in the rear for years and their stock wire going from front to back is very good quality 2/0 awg copper wire..just gotta find one that is not corroded ..cheaper option..if not id just buy some ofc on ebay.mm that weld wire is hard to work with..its not meant for cars but ppl r honey badgers...they dnt give a....
You need trunk space to get groceries and shit...bitches love groceries
The 1/0 welding wire is equivalent to an over sized 4ga or 2ga wire. Honestly I would stay away from it. At a bare minimum 2/0 welding wire or get a quality OFC 1/0 wire.
Or you can get the 4/0 welding wire for about the same or less then some audio wire. Im runing that for the easy long runs. I will use audio wire for the tight corners and into the amps just to look good.
I use nothing but Welding Cable from our local dealer throughout my entire vehicle ... with no problems what-so-ever ...
Would not use anything else !!!
  • Who's Online   0 Members, 0 Anonymous, 4053 Guests (See full list)
